Author Topic: 350A fork seal  (Read 444 times)
Offline tore
350A fork seal
« on: June 22, 2021, 02:46:16 PM »
I discovered that one of the fork legs is leaking oil. It was renovated by a company for about 2 years ago. Can not see any damages on either the chrome or the seal. The seal has likely just lost its strength.
Any suggestion of good source for fork seals?
I have a pair of fork seals from simplybearings. Worth to install those?
Tore
Suzuki T20 1969
RD350B (Indonesia) 1975
BMW R1150GS Adv 2004
HVA Roulette 1957
NV 125 1955
https://www.youtube.com/watch?v=k85mRPqvMbE
Re: 350A fork seal
« Reply #1 on: June 22, 2021, 02:54:39 PM »
I have always used the Gen Yamaha NOS ones with the steel backing.  Not had one leak yet and the oldest was overhauled by me nearly 30 years ago with new chrome on the legs. I have ones on original chrome legs still good as well, were just replaced with fork overhaul, they were not leaking but decided to renew seals with the legs stripped.  In fact, one leg was very slightly bent and I had it straightened.  ;)
Offline tore
Re: 350A fork seal
« Reply #2 on: June 22, 2021, 03:09:20 PM »
Does the yamaha genuine ones have a spring?
I can see the ones installed do not have a spring pulling the seal tight
Tore
Suzuki T20 1969
HVA Roulette 1957
NV 125 1955
Offline tore
Re: 350A fork seal
« Reply #3 on: June 22, 2021, 03:17:00 PM »
Tore
Suzuki T20 1969
HVA Roulette 1957
NV 125 1955
Re: 350A fork seal
« Reply #4 on: June 22, 2021, 07:27:51 PM »
I think they do have support springs.  ;)
Offline tore
Re: 350A fork seal
« Reply #5 on: June 22, 2021, 08:15:15 PM »
I just found out the reason for the leak. Rust! There is a pocket where water is collected at the seal. The seal has steel casing and therefore rusted. Are there any remedy for this?
Tore
Suzuki T20 1969
HVA Roulette 1957
NV 125 1955
Re: 350A fork seal
« Reply #6 on: June 22, 2021, 10:21:30 PM »
Simply bearings and bearing king do a good range of seals but check as most are for rotating shafts not axial. Exposed steel  banded ones are a pain, they rust but helps if you grease of course. Yes they should have garter springs.
Offline tore
Re: 350A fork seal
« Reply #7 on: June 23, 2021, 12:17:32 PM »
The simply bearings seal does have steel band as well as garter spring. If I understood 5port correctly, this is same setup as the original Yahama seals.
It is maybe a good idea to install and fill the space above the seal with some rust inhibitor.
Tore
Suzuki T20 1969
HVA Roulette 1957
NV 125 1955
