Author Topic: Suzuki T20 crank bearing pegs  (Read 1170 times)
Offline tore
« on: April 15, 2021, 07:53:38 AM »
Those small pegs preventing the crank bearings to turn, is it possible to drill those out?
Currently stuck and too little to grab on to pull those out.
Tore
Suzuki T20 1969
RD350B (Indonesia) 1975
BMW R1150GS Adv 2004
HVA Roulette 1957
NV 125 1955
https://www.youtube.com/watch?v=k85mRPqvMbE
Offline Bluehaze
Re: Suzuki T20 crank bearing pegs
« Reply #1 on: April 16, 2021, 12:34:24 AM »
Try carbide drill bits.
Or maybe alum?
Offline Esmerelda
« Reply #2 on: April 16, 2021, 07:23:32 AM »
High Tore EDM or spark erosion  will drill through anything conductive https://www.youtube.com/watch?v=rpHYBz7ToII .
In some engines its possible to drill a small hole to get behind or underneath the bearing peg and move them with a pin punch then close the drilled hole with a weld
Best regards
Esme
The older I get, the faster I was!
Offline tore
« Reply #3 on: April 16, 2021, 07:34:08 AM »
Or maybe alum?
Thanks Bluehaze
There are steel seats for the bearings so Alum is not an option.
I have not used carbide drills. Heard those are very britle. Need probably 2.5 or 3mm to drill out those pegs. Was not sure if those actually will drill through the bearing materials. I will try.
Skickat från min S52 via Tapatalk
Tore
Suzuki T20 1969
HVA Roulette 1957
NV 125 1955
Offline tore
« Reply #4 on: April 16, 2021, 08:19:44 AM »
Best regards
Esme
Thanks Esme
EDM seems interesting. Appears to be a project of its own though.
Tore
Suzuki T20 1969
HVA Roulette 1957
NV 125 1955
Offline tore
« Reply #5 on: April 16, 2021, 12:18:44 PM »
Maybe an option for removal of stuck screws in steel:
https://www.ebay.com/itm/2KW-Portable-EDM-Small-Hole-Drilling-Cutting-Removing-EDM-Spark-Erosion-Machine/313472325875
A bit pricey toy though. Fun is that you can drill a hex hole in the screw and use an allen key to screw it out  :)
Tore
Suzuki T20 1969
HVA Roulette 1957
NV 125 1955
