LC is easier than the RD because in the first instance the star mod is the easiest solution....not a cure to the root cause but an easy fix. Star is obviously accessible and removable without splitting the cases. And forget the different roller...that’s just smoke and mirrors by those selling ‘kit’ . Just make the points less aggressive and it instantly drops the lever pressure required to rotate the selector. Root cause resolution really just requires going through whole box and clutch ...worn dogs don’t help, rough clutch basket surfaces resist plate moving etc.
LC is also a bit short on selector arm travel, especially when the mechanism is worn...bit if a file in that helps too.
On Aircooled, all the same things apply just the star mod is less attractive due to accessibility..
Think you have an LC so I’d go for the star mod every time....there’s a good banshee youtube on it. Also reality is if you just want easier neutral...you only need to do two points...not all.
Personally I think AC RDs suffer as much....just their owners put up with it more....’they are all like it’ and we just got used to sitting at the lights with the clutch in etc etc.
