Hi again
I've just tried to remove the oil pump by undoing the the two front mounting screws as advised and the pump won't budge. Crankcase cover has not been removed.
I've given it a few gentle taps with a soft hammer and wiggled it about a bit but it still won't budge.
As I've said, the Haynes manual says you've got to take the crankcase cover off and undo the nut and spring washer holding the plastic pinion on the drive shaft, then remove the dowel pin through the shaft before you can lift the pump away.
So is this correct? Has anyone else removed the pump from the front without removing the crankase cover?
I don't want to force it anymore so thought I'd better stop and check again
