I guess my attachments were too big when I first tried to start this.
Brought the '76 RD400 basket case hoe today (well, roller with engine in frame, but a BIG bin of parts cam with it.)
I've already ordered new keys from the ebay vendor that cuts them by code#. There was a lot more there for it than I thought, but a few things that I'll have to find or make - one thing is the air cleaner cap. Also needs rear fender, rear "stay" tail light and bracket, rear signals, speedometer (the one with it was mangled), mufflers, one air cleaner joint, air filter (has a nice nest in place of one). I suspect that it needs a throttle cable, but that has yet to be proven. Needs a new chain and set cover, latch for the seat, grips (I have several new sets), tires. That should get me started.... to poverty.
I pushed the starter down by hand (no plugs) and it felt like the amount of resistance was correct. The reeds are still in place on it.
I want to clean X years of "stuff" out of the case - don't know how it was stored although it does not show typical signs of being left in the weather - more likely in the dry in a shed or barn. I want to check compression, but want to also protect it. How should I flush/oil/etc. or should I just go ahead and buy a gasket set and pull it apart? There is no gear oil in it, so I'll probably flush that side with marvel Mystery Oil and then fill with an oil good for wet clutches like Rotella T6 5W40 (which I have used in my GL1800 since new, now with 123000 miles).
BTW, check out the unmolested disks on it!
