Author Topic: removing Tachometer cable from Engine RD250B  (Read 526 times)
Offline hank22
« on: January 14, 2020, 12:28:22 AM »
 OK this should be a simple job but the part pointed at in the photo will not budge. The parts manual I downloaded has miserable resolution and the last thing I want to do is break something can someone tell me how this piece comes out [ Specified attachment is not available ]
Offline hank22
Re: removing Tachometer cable from Engine RD250B
« Reply #1 on: January 14, 2020, 12:39:27 AM »
I'm trying to fix the image
Offline hank22
« Reply #2 on: January 14, 2020, 02:05:52 AM »
The cable will not come out. What am I doing wrong
Offline GAZZATT2
« Reply #3 on: January 14, 2020, 05:42:00 AM »
The cable is stuck in the housing use penetrating oil to release it
The housing is stuck on its rubber seal carefully twist housing to free  off then pull out
XSR900  350lc 400F 400f special 400F project Mate
it did look good in a photo lance ?
Picture026" border="0
« Reply #4 on: January 14, 2020, 10:30:53 AM »
when using penetrating oil don't forget that it will mix with your gearbox oil and depending on how much you use will thin it down so i would suggest an oil change after. what i would do is remove the complete drive and do it on the bench to make it easier.
Offline Colin987
  • Location: Germany. Originally Cirencester; but who knows what the future might bring!
« Reply #5 on: January 14, 2020, 06:55:43 PM »
Parts look like this, if you're still struggling.
Colin
1974 RD250A
1973 Garelli Rekord
Offline hank22
« Reply #6 on: January 14, 2020, 11:28:59 PM »
Thanks to all for the input.I was able to remove the cable but it appears  the piece that the cable screws to (the piece to the right in the above photo) is damaged, the flange that tests against the engine case does not go fully around it's difficult to see in the parts drawing if that is normal. I'll try to get a better photo this evening.
Thank agsin
Offline hank22
« Reply #7 on: January 15, 2020, 04:42:18 AM »
It seems the concern i had with this piece was the flat spot after closer look it appears factory made this is the area hidden by the clamp.
Offline GAZZATT2
« Reply #8 on: January 15, 2020, 05:37:38 AM »
That is normal
