Hi all and thank you for your kind comments. I am including a photo of the log book supplied with the bike, as you can see, the frame is different but the engine is the same. On the right hand side of the motor, the casing was severely damaged at some time, I found it strange that there wasn't a drain plug for the oil and on inspection I found that the drain plug had been inserted from the inside and the outside was welded up? I told my mate and he said that for him it will be ok as is because for the mileage that he will be doing he doesn't mind taking of the casing to do an oil change, he also said that he has spoke to his son, who will eventually will own the bike, and he agrees too so back on it will go. I think that going by the damage to the motor, I think that the original frame probably took a good bang and was probably scrapped. I have spoke to Paul and he said he would do a dating certificate for me so re registering shouldn't be a problem. It would be nice to find out the history but I think that too much time has passed. The numbers now are, frame, PB-8506201 and the engine no. M-4902598. Any information on any of these numbers would be great but I'm not going to hold my breath.
