General > Out And About
YR5 Blyton Park 30/7/20
(1/3) > >>
D Peacock:
Took my YR5 to the annual 2t Big Bang event at Blyton Park. Was the only AC there but bike proved quite a draw  ;D
Some GoPro footage here - https://youtu.be/utLqJlU2XAY
5port:
Bike looking good!  Vid has  age blocker.
D Peacock:
--- Quote from: 5port on August 01, 2020, 12:00:28 PM ---Bike looking good!  Vid has  age blocker.
--- End quote ---
Thanks  :D
Vid should be ok now, for some reason they default to age restricted unless you choose otherwise when uploading.
5port:
Thanks Dan! :)  Enjoyed that.  What is the build state of the motor/pipes/comp?
5port:
Engine sound sweet.  You seem to use 8 as your change up revs, saw 8.5 a few times.  Obviously flexible, pulling from 5 on occasion, jetting sounding nice!  I am guessing these are a medium porting spec cylinders?  You said you were going back to standard heads, I guess also the 28mm Mikunis, foam filters and Mick Abbeys pipes?  What reeds? And plugs?   :D  Sorry, to ask but keen to know! :)
[#] Next page
