Author Topic: New (to me) 400c  (Read 6506 times)
Offline Busby
Re: New (to me) 400c
« Reply #60 on: April 24, 2022, 09:36:06 AM »
Off to PJME tomorrow with the crank and barrels. 😀
« Reply #62 on: June 01, 2022, 06:57:21 PM »
OK, The carbs are a bit tricky, lots of scope to spend £££.  ???  However, if you buy carefully, it is not too bad.  You are looking for a set of carbs marked 1A3-00.  The carbs you have are earlier RD250/350/DS7/R5? that are the wrong type. You might find that 1A3-00 carbs are expensive but, you might be lucky.  Come back here if you have problems.  In any circumstances, only buy good carbs without corrosion inside. Also, bank on buying all new jets and needles, although you can be lucky.  Don't plan on using "carb kits" for rebuild, use gen Mikuni.
Offline Busby
« Reply #63 on: June 03, 2022, 04:00:11 PM »
Hi 5port,
Many thanks for that. I did wonder why the numbers didn’t match the bike when I looked at them originally. I got sucked in because the bike only has 10,000 miles on the odometer and I thought it wouldn’t be too messed about with. Ah well live and learn
« Reply #64 on: June 03, 2022, 09:07:58 PM »
Hi 5port,
Yes.  What numbers do you have on those carbs?  They can be worth a fair bit to someone else.  ;)
However, the correct carbs for your bike are the 1A3-00.  They are quite different in detail to those earlier carbs you have.  You have probably read that it is possible to modify the later 250 carbs for the different 400's but, it is not all straightforward.  You must also decide if you really want the "correct" 1A3-00 carbs on your bike.  Price is possibly the issue.  See what you can find!
Offline Busby
« Reply #65 on: June 13, 2022, 01:02:12 PM »
Hi 5port,
Carbs are labelled 361 A3.
Just going to do a quick check to see what they fit
Offline Busby
« Reply #66 on: June 13, 2022, 01:04:54 PM »
Rd 250 73,74 and 75
« Reply #67 on: June 13, 2022, 08:11:23 PM »
Rd 250 73,74 and 75
OK.  I can't find an exact Yamaha ref for the 361-A3 but, model 361 is the early RD250 that you list and likely that they are just with a slight change.  The exact jetting would need checking for whatever they are fitted to, as these were on a 400 it is likely they are not jetted standard.  That is the same for almost all old RD carbs.  Condition is the key, if they are clean inside, that is the main thing.
Offline Busby
« Reply #68 on: July 05, 2022, 07:57:05 PM »
Hi everyone, been a little while, the 350 lc has gone lame and I have been taking a look at that. Any way some pics on progress
A7A1B34C-11D
Honestly darling it’s fine 😂
All masked waiting for paint
[url=https://flic.kr/p/2nwjjPY]
8C0D459D-9C5
« Reply #69 on: July 06, 2022, 12:29:40 PM »
Don't put alloy parts in the dishy washer, the salt and chemicals can damage alloy.  ???
Offline Busby
« Reply #70 on: August 06, 2022, 03:57:52 AM »
On with the paint
[url=https://flic.kr/p/2nCCsYu
Offline Busby
« Reply #71 on: August 06, 2022, 04:01:32 AM »
Offline Busby
« Reply #72 on: August 06, 2022, 04:03:42 AM »
Soon sorted out with a carbide cutting disk
[url=https://flic.kr/p/2nCzYyd
« Reply #73 on: August 07, 2022, 09:42:35 PM »
Not the best idea with all the bits of steel and carbide dust getting in yer new crank. Probably better to do the slight mod on the cut-out in the lower case for this, it is just alloy and you can easy clean it spotless before build.
« Reply #74 on: August 08, 2022, 11:32:11 AM »
I agree. Although, careful masking, plastic bags, vacuum, and grease application might protect you from the flying debris.
