ok....as per the usual format of the recent posts on this thread I have "some small parts coupled with a report on P&P".
The first part is the "loom" for the speedo bulb
235-83536-21 SOCKET, meter..... . I"ve spent an innordinate amount of time checking the manuals, cross referencing with other models and trawling Ebay for the right part here. As mentioned several times before I feel the best way to get the right part is buy a second hand part as it will 9 times out of 10 be correct. When you buy NOS it can be a superceeded part or arrive without a tag and you"re not really sure.
Some time ago I got the loom for the multi-bulb tachometer from a guy breaking a CS3 in America but he didn"t have the speedo one. A few weeks ago I came home drunk and trawled Ebay till the early hours looking for the bulb holders for both the speedo & tacho and emailed a guy in the USA who was selling a the clocks and asked him if he"d pull the bulb holders of and sell separatley.
I woke up the next morning to remember I
already had the tacho ones
. Luckily the guy wasn"t keen to sell them so I finally took the plunge and just bought a NOS speedo one I"d had on my watch list for months!!
It arrived today, slightly overpacked, and the seller used USPS First Class Mail International (I"ll call it FCMI for short) costing $3.66/?2.44
. The part was $19.99/?12.22 which is ok I suppose.
speedo bulb holder 235-83536-21 all the way from USAThe second part is the rubber damper for the speedo
214-83523-00 DAMPER..... which I bought a while ago and I"m still amazed at how a part, which is almost undamagable, needs so much packing. It also cost twice what the other part did to post $7.81/?6.11 The seller originally had it listed under USPS Priority Mail International (we can abbreviate it to PMI)and I didn"t keep a note of how much that was (more than $20 I think) but I have found that, if you ask, many sellers will agree to FCMI and the cost drops - big time. This seller did this but used a Small Flat Rate Box which is only available for PMI as far as their website shows. You can"t mix the two services so he"s ended up paying for the weight of the empty box really.
It was still cheaper than the original price but not as cheap as the seller who didn"t use a USPS box.
speedo damper 214-83523-00 arrives wrapped in large sheet of paper inside 2 plastic bags and carboard box. overkill?The 3rd part is the STD CS2E/CS3E throttle cable
237-26311-00 mentioned in the previous post. The seller originally quoted $33.55 for shipping but then shipped in a flate rate envelope quoting $19.95 for it but the actual cost was only $13.55. I still saved nearly $20 by asking tho. Strangely the slip on the envelope shows that the item weighs 32oz - 2lbs but I very much doubt the throttle cable would weigh that much. The envelope can be used for up to 4lbs so why would fabricate a weight....
USPS Priority Mail International Flat Rate Envelope that cable arrived in apparently weighing in at 2lbs...same as a bag of sugarIn fairness to the sellers they prefer to use Priority Mail International as there is a tracking system on this so they have some re-course if things go missing - or people
claim they go missing. First Class Mail International (let"s abbreviate it to FCMI) doesn"t have this so some sellers won"t use it as they may have been stung in the past. I have received loads of items by FCMI and never had a problem.
As for using a flat rate box or flat rate envelope again you can"t really fault the seller as it speeds up the weighing/packing/pricing process as its "one size fits all". You can send up to 4lbs in them and price doesn"t alter. Its currently $13.95. You can get bigger boxes that take up to 20 lbs.
flate rate box & envelope clearly marked Priority Mail and warning on side of box that they can only be used for that service
