Those small pegs preventing the crank bearings to turn, is it possible to drill those out?Currently stuck and too little to grab on to pull those out.
Try carbide drill bits.Or maybe alum?
Quote from: tore on April 15, 2021, 07:53:38 AMThose small pegs preventing the crank bearings to turn, is it possible to drill those out?Currently stuck and too little to grab on to pull those out.High Tore EDM or spark erosion will drill through anything conductive https://www.youtube.com/watch?v=rpHYBz7ToII .In some engines its possible to drill a small hole to get behind or underneath the bearing peg and move them with a pin punch then close the drilled hole with a weldBest regards Esme
