Author Topic: Cold starting  (Read 15597 times)
Offline Hazey
Cold starting
« on: June 08, 2014, 11:04:06 PM »
X wont start on the kicker from cold ? bumps ok after a bit of a leg it  :o and starts on the kicker no problem when warm.
I threw some b8hs at it tother day but has not helped the situation. when it does start up from cold,its excessive smokey,compared to my 400f which always starts 1st 2nd kick.
Any ideas chaps ?
RD 400F
YB100 Stock,in build
YB100 Mutant.in build
Cr80
Motohispania rx50
Vino 50 Scoot
You dont stop having fun when you get old........
You get old when you stop having fun !!!
Offline Panuno
  • Hadleigh, Suffolk
Re: Cold starting
« Reply #1 on: June 09, 2014, 06:55:50 PM »
Iridium plugs? Bit dear-ish though @ £10 each...
I think it has the Zeeltronic iggy, so not the easiest thing to check
Member 117
RD 350B:  K75 'Flying Brick': RD 250B in several Boxes..   Best 350 RD '013
www.admould.co.uk
Offline mervin
Re: Cold starting
« Reply #2 on: June 09, 2014, 06:57:13 PM »
Is the oil running back from the pump  i wonder , seems very strange my 400 started first kick after several month layup recently, is choke ok not loose or owt, any air leaks on inlet side of things
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.
 Alexei Sayle
Offline keith rdc
Re: Cold starting
« Reply #3 on: June 10, 2014, 07:37:42 AM »
Last time I took X out on the New Forest run she was a bit reluctant to start cold, once fired up no problem after that and how good do those pipes sound 8) 8) 8) 8), love X :-* :-* :-* :-* :-*
Offline SupeRDel
  • Club Magazine photographer, writer and editor.
Re: Cold starting
« Reply #4 on: June 10, 2014, 12:45:47 PM »
When mine gets like that its usually the plugs getting a bit old.
Putting a new pair in transfors the starting
I usually go 3 years a pair (5 to 6000 miles'ish) - How old are the set in there now
« Last Edit: June 10, 2014, 12:48:12 PM by SupeRDel »
 --  Articles always needed
Re: Cold starting
« Reply #5 on: June 10, 2014, 01:07:18 PM »
There a year old Del, they were put in on the engine rebuild last year.
I think Hazy has already put a new set of B8s in and its still difficult to start from cold.
Offline Hazey
Re: Cold starting
« Reply #6 on: June 11, 2014, 09:00:17 PM »
See my post del ......... I threw some b8hs at it tother day but has not helped the situation.
Did fire up on a shorter bump yesterday evening from cold,left parked up for an hour or so and fired first kick.
RD 400F
Cr80
Motohispania rx50
Vino 50 Scoot
Re: Cold starting
« Reply #7 on: June 12, 2014, 08:03:46 AM »
Have you put any fresh fuel in yet Paul
That's been in there since good Friday, I would not of thought it was stale yet but worth a try.
Offline SupeRDel
Re: Cold starting
« Reply #8 on: June 12, 2014, 08:14:00 PM »
Howz the battery then.
Similar symptons to mine when battery was on its way out. Have you tried putting the battery on charge overnight then disconnect and try to start from cold.
Offline dandywarhol
Re: Cold starting
« Reply #9 on: June 12, 2014, 09:00:12 PM »
Check the hose between the carbs for the fuel enrichener is intact.
Whale oil beef hooked
TD1C, RD250A, TRX850, H*nd@ Dylan scoot
Re: Cold starting
« Reply #10 on: June 12, 2014, 09:29:07 PM »
New fully charged battery and its got electronic ignition so even if the battery was flat it would be OK.
Offline Hazey
Re: Cold starting
« Reply #11 on: June 12, 2014, 10:27:02 PM »
I did charge the battery over night,when it arrived  here.
Carb choke link pipe good.
Fresh fuel tother night.
I will use it sunday for the car/bike show in exeter,so see how that goes.
Its also got a oil leak from gear lever shaft,i dont have a spare seal here,so will keep the gearbox topped up.
RD 400F
Cr80
Motohispania rx50
Vino 50 Scoot
Re: Cold starting
« Reply #12 on: June 13, 2014, 05:47:38 AM »
I assume the choke is actually working (choke on with warm engine, engine dies)
Any sign of an air leak?
Offline Hazey
Re: Cold starting
« Reply #13 on: June 13, 2014, 11:43:00 PM »
Yea choke operated while warm and running,defiantly richens up.
Going by plug colour its running slightly rich
RD 400F
Cr80
Motohispania rx50
Vino 50 Scoot
Offline Paul Ambridge
Re: Cold starting
« Reply #14 on: September 03, 2014, 10:18:35 PM »
If the bike has a zeeltronic system fitted you must use Resistor plugs. ie BR8ES OR BR9ES.
