Author Topic: Replacing 1974 RD350 ignition system with RD400E ignition system  (Read 607 times)
0 Members and 2 Guests are viewing this topic.
Offline elram
Fellow Riders,
Could someone please let me know if 1974 RD350 ignition system can be replaced with RD400E (2R8/2R9) ignition system (stator plate, magnet, CDI and ignition coil)
Thanks in advance.
Offline RDJames
Re: Replacing 1974 RD350 ignition system with RD400E ignition system
« Reply #1 on: May 26, 2023, 06:34:06 PM »
plus crank, loom and more
RDJames on Ebay
http://stores.ebay.co.uk/rdjames
Never take life too seriously, no one gets out alive anyway
« Reply #2 on: May 26, 2023, 07:20:53 PM »
As David implies … Pretty much the whole electrical system… including ignition switch , kill switch…
Offline elram
« Reply #3 on: May 26, 2023, 11:34:52 PM »
Thanks a lot for your input RD James and betty ford.
RD James, please let me know if the tapper of the crank end of RD350 and RD400E are not same.
Thanks a lot.
« Reply #4 on: May 27, 2023, 08:50:26 AM »
Hi,
The taper is different.  Dave and Betty are right, there is a whole load of differences.  You could do it but there are many changes. Here is my list!
Crank. 2R8 needed or Frankenstein with 2R8 left web and taper.
Crankcase. Stator pin needs removed and CDI stator mount holes need drilling.  "F" timing mark needs making.
Left case cover needs hole or extension welding for CDI trigger coil.
Frame needs mount welding on for CDI box.
Special electric loom for generating circuits and CDI wiring.
Reg/rectifier.
Ignition coil and mount.
Ignition switch.
Kill switch.
I don't think I know of anyone doing it properly.
Offline elram
« Reply #5 on: May 27, 2023, 10:01:15 AM »
Hi,
Reg/rectifier.
Ignition switch.
Kill switch.
Hi 5port,
Thanks a lot for your input.
Could you please let me know why the ignition switch and the kill switch needs replacing?
I will give it a try and report the outcome.
Thanks a lot.
« Reply #6 on: May 27, 2023, 12:17:54 PM »
Hi,
Reg/rectifier.
Ignition switch.
Kill switch.
Hi 5port,
Thanks a lot.
Hi,
Because the CDI Ignition circuit is different to the Points circuits.  The Points circuits are "made" by the kill switch and the Ignition switch to complete the LT circuit and make it live to work.
The CDI system is self generating and the CDI wiring to the different CDI Ignition switch and CDI Kill switch act as earth paths to kill the CDI LT.  That means the wiring and switching functions of the ignition and kill switch are different between the two types, which means you need the different switches and a bespoke wiring loom, unless you are a god with sparks.
Overall, this could be done, but I have not done it.
Try reading-up and working-out the wiring diagrams first, because you are going to need to!  Also, the engineering of the CDI to the cases may need welding and machining, I am not certain that the bosses are even there on the points cases, although the CDI bikes have the earlier undrilled bosses still on them, the earlier bikes had no idea that the CDI would come along!
Offline elram
« Reply #7 on: May 27, 2023, 01:23:01 PM »
Hi 5port,
Thanks a lot for the detailed information.
After going through the information that you have shared, I am fairly confident that I can try this conversion.
One more clarification regarding the crank end taper difference.
Instead of replacing the RD350 AC left crank web with 2R8 left crank web, can I replace the tapered center of 2R8 magnet (The keyed sleeve) with a magnet center that matched air cooled RD350. I was informed that the Yamaha RX100/RXS magnet center has same taper as the air cooled RD350.
Thanks a lot for you time.
Offline chrisg.007
« Reply #8 on: May 27, 2023, 02:30:14 PM »
If you want to move away from points, isnt there a specific system for your bike?
Growing old is compulsery, growing up is optional.
RD400D
RD250E  350 conversion
Suzuki X7
RD400E
RD350LC  4LO Blue/White
RD350LC  4L0 Red/White
Offline elram
« Reply #9 on: May 27, 2023, 03:14:17 PM »
Hi Chrisg.007,
Yes, there are few options available in the market.
I am running CDI in two of my RDs (1973 and 1975) that is designed and manufactured in India, goes by the name "APS ignition system" It works flawlessly and I am happy with it.
I am fascinated to try 2R8 ignition system in an air cooled RD 350 as that is factory fitted.
Thanks a lot.
« Reply #10 on: May 27, 2023, 03:44:19 PM »
If you were building a project up from scratch… it’s relatively easy to incorporate the cdi ignition… as essentially you just build E/F electrics onto the earlier bike. The E/F is also a better crank … no lead weights to come loose etc..
« Reply #11 on: May 27, 2023, 03:58:48 PM »
#elram
If you do decide to go for it, then maybe photograph and document your progress, for a feature in future edition(s) of WellaRD.  ;)
Yam RD350
Yam R5
Offline elram
« Reply #12 on: May 27, 2023, 04:56:04 PM »
Hi betty foRD,
The build is completed few months back. Hence, I will try to modify 2R8 magneto.
Gr8uncleal,
Yes, I will do that.
« Reply #13 on: May 27, 2023, 05:28:25 PM »
Hi betty foRD,
You can’t do that as you need the end of the crank to be longer… the tapered shaft is TOTALLY different… just no way to adequately use the existing crank and cdi E/F rotor
Online GAZZATT2
« Reply #14 on: May 27, 2023, 05:31:06 PM »
Don’t Vape do a system that fits ?
XSR900  400f special 2nd 400F special
it did look good in a photo lance ?
Picture026" border="0
