Author Topic: Oddjob,s RD400C  (Read 7346 times)
Offline Mally
Re: Oddjob,s RD400C
« Reply #15 on: April 24, 2023, 11:08:48 AM »
Yeah , that size of photo is a lot better , you could get away with attaching 2 or 3 to each post at that size.
Great work on the restoration, it’s always satisfying to see progress and a bike emerging from a loads of parts . All the best with the project.
Kawasaki Z900 A4 , 1976
Yamaha R6, 1999
Yamaha RD 250 D, 1977
Raleigh Chopper Mk2 , 1973
Offline Mally
Re: Oddjob,s RD400C
« Reply #16 on: April 24, 2023, 11:16:04 AM »
I am going to clean up these bits from the rear wheel as best I can and replace anything that is knackered
I used a brass wire brush on a drill to clean those parts up then got them
Nickel plated . Worked a treat, I used these.
https://www.toolstation.com/search?q=wire+brush+for+drill
That lot in the photo was £80 to nickel plate.
Yamaha R6, 1999
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #17 on: May 06, 2023, 08:13:18 PM »
I have bought some new parts for the swingarm. Yambits for new covers and a place in Germany for brass or bronze bushes as in the photo
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #18 on: May 06, 2023, 08:18:49 PM »
The bits that go inside the bushes I have zinc plated myself as I bought a zinc plating kit a couple of years ago as there is no platers  close to me and its probably a bit cheaper than a professional
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #19 on: May 06, 2023, 08:26:14 PM »
I would advise anyone fitting new bushes to make a homemade press to fit them, I bought a 12mm stud bar with 4 nuts and some large washers then fitted it through the swigarm and tightening it up slowly and it presses the bushes in.
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #20 on: May 07, 2023, 10:16:56 AM »
Frame and wheels
pidjones
Re: Oddjob,s RD400C
« Reply #21 on: May 07, 2023, 11:30:58 AM »
Nice roller. Moving forward!
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #22 on: May 16, 2023, 06:12:56 PM »
I took the crank to PJ on Friday with the barrels to be reconditioned and the cases have gone to be aqua blasted,  I am cleaning and respraying the brake bits ready to re-fit
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #23 on: June 25, 2023, 07:04:15 PM »
Finally got the crank and re-bored cylinders back from PJ
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #24 on: June 25, 2023, 07:06:21 PM »
Also had the cases aqua blasted and they have come up a treat
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #25 on: June 25, 2023, 07:10:41 PM »
The silencers, mudguards and headlight rim have gone to Castle Chrome to be re-chromed. When I paid for the crank at PJ I mentioned about the 10% discount but he said they haven't been doing that for about four years .
Offline Mally
Re: Oddjob,s RD400C
« Reply #26 on: June 26, 2023, 08:19:54 AM »
Crankcases look better than new , look forward to seeing the chrome work when you get it back , must cost a fortune now.
Yamaha R6, 1999
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #27 on: June 26, 2023, 07:46:52 PM »
Invoice from pj and the chrome is quoted at 750 + VAT but that is what it is to get it right and I've still got the paintwork to get done, may have to get a second job  ???
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #28 on: June 26, 2023, 07:53:46 PM »
Forgot to mention shaunthe2nd sorted my clocks for me and has done a cracking job highly recommended 👌
Offline Oddjob
Re: Oddjob,s RD400C
« Reply #29 on: August 04, 2023, 09:00:16 PM »
Finally have had time to get the engine back together and fitted back in the frame. I resprayed the casings and cylinders in PJ1 satin black .
