A Bit of an update so we had a summer of fast fun and wheelies but not without issues, oil leaks despite new seals and blowing crank seals twice plus chasing a running issue meant it was going to come apart fully over winter as I had only dropped the bottom case off when I changed the crank seals all 3 times and wanted to fully inspect bores heads etc.
So having done 580 miles, some at full chat plus several dyno runs, it was a nice crisp morning and was running particularly well and cleanly to 10,500 coming back from super sausage cafe through Milton Keynes I thought I heard a high pitched squeak coming out of a couple of roundabouts then 2 bikes came past on a long straight and I'm giving it beans 110 Changing into top and pop goes the weasel well l/h piston anyway.
So The rebuild began a little early lol L/H piston holed alloy sprayed L/H big-end and mains plus both heads cracked in 5 or 6 places around plugs hence squeak.... both barrels are on 1.00mm over but both exhaust ports have deep historic squared off ring damage.... omg not what I expected as just made 38.5bhp! essentially my dyno man took a look and said they were scrap...... or not lol Talko had to go 2.5mm oversize to clear damage fully using dt125lc pistons which have larger ports on rear and nice cutaways on the side to aid transfer as added bonus making it now 270cc. The heads had both cracked and the blowing seals was all down to it being over compressed which I only discovered after lots of maths and stuff like PI checking the compression ratio on the good side!! This means new heads have been machined out for the 56.5 bore and squish area modified but not fully skimmed yet until it's rebuilt and rechecked squish/compression ratio etc. The crank has been fully rebuilt with RG500 big-ends and balanced by Grampians. We are aiming for mid 40'sbhp at rear wheel with this now.
I'll add pictures at later date
original RD250 1.00mm over piston and DT125 .50mm over size so 56.5mm bore
head with enlarged chamber 57mm and modified squish before I installed and will recheck squish/compression ratio
barrel ports
crankcases all cleaned and ready for fully rebuilt crank with RG500 big ends
and all together now just need to check squish etc and source some new expansions
