So, I thought I will post these pics up and come back and insert with words after cooking and drinking!
Top end.
Mmmm, Nice spare ribs in BBQ and our own Honey marianade!
This top end is USA sourced RD350 cylinders and UK sourced 1A2 RD250 heads. The cylinders had some rebore mistakes and were on +0.25. Mick had to take them to +0.75 to get them OK, after the porting. I am not going to list Micks porting figures precisely because that is his info. However, as I said before, we started with the RD350LC and went onwards. The exhaust port is wider and shaped more like a rugby ball. So, it gets earlier opening and greater time/area, closer to a 350YPVS or TZ750. Now, of course, you can make an engine a high rev only monster if you go too high with the exhaust port but, the transfers are also matched and I do not expect a light-switch powerband. In fact, these cylinders came with the Ex ports raised to about where they are now, and no other mods! So, I think they will now be Hot, but not too hot to handle!
You can see that the usual RD250/350 top gasket step has been machined back to a flat face. This is to allow the use of a later RD type full gasket that has better reliability.
Cylinders.
Seen here, the liner is cut back to favour the main transfer ports. The liner near the aux T.fers is not cutback much. This is just because it works this way! What you can't really see is how Mick has not just hogged-out the passages. They are still shaped to work well.
Heads.
The Heads are important. They control the squish and CR to give good combustion. There are lots of options but, it should be possible to get a good performance with modified RD heads. These started as 1976 onwards RD250 1A0 heads. They have a greater thickness than earlier heads and that helps with strength and heat dissipation. They are wider than the early 350 cylinders and I have cut them to match. However, if you felt that you had a heat problem, you could run with the extra width fin. Mick has done a great job recutting these heads. With just a 0.25mm face cut, he has then cut an 8mm wide squish face and then a lovely hemi bowl to give exactly 22cc.
The sparkplugs need a copper washer to give a precise fit with the slight change in thread depth.
You can change a few things such as gasket thickness to get your squish/CR modified. I would likely get another set machined if I need different details. These cost about £40 a set so, no need to buy fancy £600 heads IMO, Well not at 50bhp level anyway.
BTW, The anti-ring fin dampers are made by me from 10mm dia Hi-temp silicone rubber rod. Each one is 11mm and a strong press fit.
Pistons.
A great big Thank-you to Steve Moffatfor these pistons. They are heat-cycled TKRJ 4L0 pattern. Now, they are sized by Mick at 2 Thou inch skirt clearance. Bear in mind, they will run at a considerably higher heat-load than an Aircooled RD350, and that is why Mick recommends 2Thou inch in this track engine.
These pistons were designed for the 47bhp RD350LC and, I think they will good to start with in my 50bhp track bike. Once again, thank you Steve!
