Take both plugs out..
Put a small 12v bulb, like a neutral or speedo/tacho illumination bulb across the points, ignition on, kill switch to run. Turn the engine slowly over one revolution, The bulb should light up when the points open, and go off when closed, about half a turn on and half a turn off.
Do this with both sets of points.
If this works the points have a 12v feed through the coil primary and the points are opening and closing correctly.
It does not test the capacitor (condenser) or the high tension secondary, plugs, or plug caps, in any way.
