Author Topic: C and D and E and F - Differences  (Read 26502 times)
Offline SupeRDel
« on: October 18, 2007, 04:20:38 AM »
One of the most common questions is the "Wot model have I got" - "Does this part fit this model"
You see many parts for sale on ebay that are sold RD250/400. Well sometimes they will but a few parts won"t.
Usually most sellers just don"t realise so you can"t blame them and don"t trust those that say - "It has a seat with a cowl on so it must be a E or F"
Many parts got swapped around during the years.
Starting with the obvious - the numbers!
The frame and engine should match on genuine bikes - No exceptions. But don"t be surprised to find that some owner or other has swapped a blown engine at sometime in a bikes history.
RD400
Model Numbers Europe.
1976.. 1A3-000101 C model
1977.. 1A3-100101 D model
1978.. 1A3 110101 E model
1979.. 1A3-330101 F model
USA.
1976.. 1A1-000101 C model
1977.. 1A1-100101 D model
1978.. 1A1-110101 E model
1979.. 2V0-000101 Daytona
Besides the frame and engine numbers some of the common differances are shown below.
If your footrests are bolted to the side of the frame as per the photo below then you have a E or F model (1978 - 1980).
Wheels - The RD400 C and D models came with plain alloy coloured wheels with non machined edges (red arrow) to the spokes................
All the later alloy wheels had machined edges to the spokes. I had a 400D brand new with plain alloy coloured wheels other members say that they had D models with machined and painted wheels - so there may have been some cross over. In fact the 1977 Yamaha sales brochures has the 400D with plain wheels and the identicle 250D brochure has the 250 with painted wheels.
The machined edge wheels came painted red or black.
One thing is for sure - wheels with rough cast spoke edges were never painted.
The 250/400 never came with an alloy wheel with a rear drum brake. These types of wheels do appear on some RD"s.
Those wheels either came from a later XS250/400 of are aftermarket made by someone else.
Topic under construction
 --  Articles always needed
2archrival
« Reply #1 on: May 20, 2010, 03:54:20 AM »
Ok having just gone through the angst of doing an engine rebuild and cannibalising a 250 c for bits to go on a 250E model can i add to this.
for a start, the primary drive gear is thicker on the 250C, as is the drive ring gear on the clutch basket.  you need the primary drive and the clutch basket to match. moving a bit further back the layshaft gear is different as is the kick start.  The lay shaft gear is thicker and is actually two gears one behind the other.  the kickstart works on the gear closest to the engine and the rev counter drive works off the outer gear.  The rev counter gear is a different size and number of teeth - 250E is smaller.
Essentially to use the 250C clutch and basket which was my original intention, I have had to cannibalise the rest of the running gear to get it all to align and work.
Oh yes final point.  I have had to build mine and leave out the rev counter drive.  The final and most frustrating part.  the shaft the rev counter sprocket drives is different, on the 250C it sits prouder from the engine cases and has a shoulder to move the plastic sprocket away from the engine cases to enable the plastic sprocket to mesh with the outer gear of the layshaft.  That was most frustrating because that rev counter shaft can only be changed if you do a full engine strip.  Why was I frustrated - because guess where I was in my engine rebuild when i found all this out - you guessed it with the cases all rebuilt. That is a job that can wait for the next time I need to rebuild that engine
Hope that goes some way to help others!
Offline YellowYam
« Reply #2 on: May 23, 2010, 07:33:29 PM »
Wheels: RD250D & RD400D
Del,
I can see that there is some confusion about whether the D models had Rough Cast Wheels or whether some had Painted and Polished Spokes.
The USA model RD400E (virtually the same as the European RD400D) had Painted with Polished Spokes Wheels, interchangeable with the European RD400D - this is clearly photographed in one of the USA Sales Brochures for the Silver RD400E.
Your RD250D Sales Brochure with the Black Wheels - are you definately sure that it is not just "shadow" created to make the inside of the Spokes appear to be painted Black, I cannot recall any of the RD250D or RD400D models having such Painted and Polished treatment in their day (back in the 1970"s/1980"s).
I have 2 RD250D Sales Brochure Photos, one for the Silver model but it is clear that the inside of the Wheel Spokes, although they appear to be Black, this is just shadow created by the photography. Ditto for the photo I have of the RD250D in either Chappy or Modena Red (only the RD400D came in that colour)!
YellowYam
Offline YellowYam
« Reply #3 on: May 23, 2010, 07:33:54 PM »
Speedometer & Tachometer
Another difference between the models is the Speedometer and Tachometer fitted, there were 3 types (4 if you include the Daytona"F" & "G" models):
1) Early type:
The Speedometer is marked in upper-case for either MPH or KM/H (or KMH). The Tachometer is marked in upper-case for "RPM x 1000. The "Red Line" commences at 7500 RPM (according to the Owner"s Handbook) but maybe 8500 RPM. The Tachometer houses the Idiot Lights for NEUTRAL and HIGH BEAM settings (marked in upper-case).
This Early type of gauges were fitted to all European RD250C and RD400C models from new, it is known to have been fitted to all USA RD400C and some early USA RD400D models.
2) Later type:
The Speedometer is marked in upper-case for either MPH or KMH. The Tachometer is marked in upper-case for "RPM x 1000. The "Red Line" commences at 8500 RPM. The Tachometer houses the Idiot Light for HIGH BEAM setting only (matked in upper-case).
This Later type of gauges were fitted to all European RD250D and RD400D models from new, it is known to have been fitted to later USA RD400D models. It was fitted to all USA RD400E models (very similar in spec. to the European RD400D).
3) E Model type:
The Speedometer is marked in lower-case for either mph or kmh. The Tachometer is marked in lower-case for "rpm x 1000. The "Red Line" still commences at 8500 RPM. The Tachometer houses the Idiot Light for HIGH BEAM setting only (in upper-case).
With the Lights turned on, the Gauges glow Green (instead of White) to illuminate the Engine/Speed Readings. The E Model type of gauges were fitted to all European RD250E, RD400E, RD250F & RD400F models (the RD250F & RD400F models were officially called the "1979 E model" from new to differentiate them from the "1978" E models.
4) Daytona type:
The Daytona "F" & "G" models had re-styled Speedometer and Tachometer fitted, these models were not imported into Europe (because the "LC" models were imported here earlier than elsewhere).
YellowYam
Offline Afterdarkmark
Re: C and D and E and F - Differences
« Reply #4 on: June 20, 2014, 07:03:41 PM »
Any idea of the purpose for the bump on the left casing?
I just bought a 400F engine with no left casing and wondering if an earlier version will fit.
Offline 2r9
« Reply #5 on: June 20, 2014, 09:34:55 PM »
The bump on the later casings accommodate the CDi pick-up that is used on E/F engines.
« Reply #6 on: June 21, 2014, 04:56:04 AM »
Thanks for the quick reply!
Offline wayne j
« Reply #7 on: September 06, 2014, 05:31:57 PM »
hi guys talking about engine and frame numbers mine starts with  1A2 any idea what year because my number dosent match my number plate it says at the dvla its a 350 when i am sure its a 400e  :-\
Offline RDnuts
  • RDnuts
  • nuts about rds
« Reply #8 on: November 08, 2014, 12:55:48 PM »
ia2 is a 250 need more info to id it correctly the full vin number and engine number if different then can id the lot
RDnuts 18 RDs tooooo many even for me , the best things in life aint free, non fully paid up x member 2376 owner and restorer of the first rd to come to the uk RYN51L front page of april 2013 classic bike my claim to fame
Offline magicfingers62
« Reply #9 on: November 08, 2014, 08:04:57 PM »
I know the basic info but can any one fully Identify this Vin 1A2. 225796 :)
Offline RDnuts
  • RDnuts
  • nuts about rds
« Reply #10 on: November 09, 2014, 03:12:39 PM »
250e
« Reply #11 on: July 23, 2018, 08:59:49 PM »
engine rubber mountings my 400dx has them my 250dx has not.
was it only the 400s that has them
Yes, in the aircooled.
Offline Angel Grinder
« Reply #12 on: August 20, 2018, 12:01:24 AM »
What's the score with wire wheels on the C, D, E and F? A friend of mine has a pair of wire wheels which have the C/D type discs front and rear.
I believe that the 250C only came with wire wheels (but had a drum rear) but could you opt for wires on the 400C or the 250/400D and E/F?
« Reply #13 on: August 20, 2018, 07:15:59 PM »
Hmmm, it is a bit complicated because different markets had different specifications, then there are greys, special imports and modern imported, etc.  First thing, the spokey hubs are different on OE front/rear Disc braked C/D against E/F.   Yes, UK market 250C was spokey with rear drum only but W.German (and prob others)  was rear disc.  Think 400 UK/Euro was always choice and always with discs. Cheers.
Offline torwel
« Reply #14 on: December 23, 2018, 10:15:21 AM »
Hi
About the numbers, I do have 1A3000010 frame and engine (RD400C). This is a little odd if one expect first number to be 101. Could this bike have been shiped ahead to Europe for shop display before "first" production?
TW
