Author Topic: 1E7-14371-00 RD125DX Choke Plunger  (Read 489 times)
Online grahamsmythe
« on: January 15, 2020, 12:56:46 AM »
I'm not entirely convinced the choke plunger on my carburettor is sealing correctly.
I've had a look at most of the favourite places, and it would seem that NOS plungers are like hen's teeth to get hold of.
Has anyone had any luck refurbishing an old one - ie. by replacing the bottom washer material?
Offline tractorman
Re: 1E7-14371-00 RD125DX Choke Plunger
« Reply #1 on: January 15, 2020, 10:10:10 AM »
I may or may not be able to help, it depends on the part numbers and what they mean. Your part number begins with 1E7 but earlier models begin with 396. The rest of the number is the same. I have a carb from a Yamaha GT80, and the plunger number is, 3671437100. So, is this the same part? Maybe someone else could help here. If it is, then I can let you have the part to see if it fixes your problem.
Online grahamsmythe
« Reply #2 on: January 15, 2020, 12:09:09 PM »
Hi @tractorman Thanks for your reply.
This is the part
« Reply #3 on: January 15, 2020, 12:32:09 PM »
Don't know if this will help, but going by Tractorman post I did a quick search and found this
scroll down to number 25
https://jandjcycle.com/Parts-Finder/yamaha/motorcycles/1981/dt80h/carburetor-dt80h-j/00000000-0000-0000-0000-039308531981
and this
https://www.cmsnl.com/products/starter-set_29j1410a00/#.Xh8E0siTLIU
so a new part number for that, maybe a new part number for your bike.
Online grahamsmythe
« Reply #4 on: January 15, 2020, 12:45:25 PM »
I don't think that's my carburettor.
Offline tractorman
« Reply #5 on: January 15, 2020, 12:49:43 PM »
That is the same part as my GT80. TK Carb. The plunger measures 3.5cm from top to bottom and the plunger part is 3/4cm long and about 1/2cm wide.
« Reply #6 on: January 15, 2020, 02:54:15 PM »
Graham, I have sent you a pm.  :) :) :)
Yam RD125B (probably!) now being reassembled
Yam AS3 in boxes
Offline 76rd200
« Reply #7 on: June 08, 2020, 10:44:01 PM »
Was there any solution to this as I might be having the same problem.
Bikes
Yamaha RD125 1976
Kawasaki KH250 1977
Kawasaki Z900 1976
Lambretta Li special 1968
Fantic Caballero 1973
« Reply #8 on: June 09, 2020, 07:45:27 AM »
Have you been able to take it apart? They can stick and just need a little WD40 to free up.
Yam AS3 in boxes
Offline martin1957
« Reply #9 on: June 09, 2020, 09:51:37 AM »
When the starter jet plunger is in its normal down position, off, it cuts off the starter jet air route. The rubber on the end seals the starter jet fuel outlet.
With no air to create a depression, there is no pull on the fuel through the jet, so the rubber seal does not have too much sealing to do. All the spare ones I have for VM17 carbs have a rock hard rubber insert.
I think it would be possible to pick out the rubber seal and press a new one in........
Just my thoughts.............
Retired Widowed Electronic Test Engineer (Avionics), Age 62, Owned P50, PC50, SS50z, YAS1, YDS7, RD350B till 1978, then KH400 from 2009 onwards. Have a fully restored YAS1 on the road, and an AT3. And now a Suzuki T125 Stinger to get fired up, with another Stinger in boxes....
Offline 76rd200
« Reply #10 on: June 09, 2020, 08:13:01 PM »
My choke plunger seems to move ok but I think its more a case of not totally sealing.
I will try taking it out at the weekend. Im guessing modern fuel has probably hardened the seal.
Bikes
Yamaha RD125 1976
Kawasaki KH250 1977
Kawasaki Z900 1976
