Author Topic: Gr8uncleal's grotto (aka parts id help needed please!)  (Read 164 times)
« on: December 15, 2019, 06:44:26 PM »
I went over to Andover to see Santa last week and in the box of goodies that he gave me were some that I couldn't identify and so I was wondering if you wonderful folks could give me some pointers. I'm not looking for specific model fitments, just a nudge in the direction that I should be looking.
It will be easiest for me if I make a post for each item, so bear with me a few minutes whilst I load the photos.
This is the first one, likely to be small capacity single cylinder. I'm guessing that those are a lighting and ignition coil alongside the points, but no condenser though. Three wires coming off the bracket - pink, white and black and white. Manufacturer is Mitsuba.
« Last Edit: December 15, 2019, 06:46:12 PM by Gr8uncleal »
Yam RD125B (probably!) just received
Yam AS3 in boxes just received
Re: Gr8uncleal's grotto (aka parts id help needed please!)
« Reply #1 on: December 15, 2019, 06:48:08 PM »
Second one. Three wires, all black and red, going into a triangular block connector. Manufacturer is ND (Nippon Denso).
« Reply #2 on: December 15, 2019, 06:51:19 PM »
Third one.
I known the plate is broken, but the parts might still be serviceable.
Would those two black units be pulsers for a twin with CDI?
« Reply #3 on: December 15, 2019, 06:57:11 PM »
Fourth and last one on this thread.
Definitely Yamaha as still in original packaging. However, the writing on the pack is badly rubbed.
Dimensions as follows:-
Length = just under 26mm
External diameter = 14mm, reducing to about 13mm in the centre groove.
Internal diameter - 10mm.
Thanks very much.
Alan
« Last Edit: December 15, 2019, 06:59:36 PM by Gr8uncleal »
