Author Topic: yr5 engine problem ( no power)  (Read 376 times)
Offline poggy
« on: November 08, 2018, 12:42:08 PM »
engine will start up first kick . right hand cylinder will run ok on its own with carb air screw 1 and 3/4 turns out but left cylinder needs to be nearly 3 turns out before it will run on its own . will rev ok but on the road no power and misses on left side .new points , plugs , condensers, different coils, different carbs ( all been cleaned)
Offline chrisg.007
Re: yr5 engine problem ( no power)
« Reply #1 on: November 08, 2018, 02:01:03 PM »
Could be anything. Are your baffles and exhausts clean? Are the points set correctly using a dti? Has it ever run right or is it a new purchase?
Growing old is compulsery, growing up is optional.
RD400D
RD250E  350 conversion
Suzuki X7
RD400E
Offline poggy
« Reply #2 on: November 08, 2018, 02:31:03 PM »
not run ok since a engine rebuild . all set up ok . exhaust and baffles clean. thought it might be left crank seal but still same after changing that
Offline chrisg.007
« Reply #3 on: November 08, 2018, 06:44:35 PM »
what make of pistons have you fitted?
RD400D
Suzuki X7
RD400E
Offline poggy
« Reply #4 on: November 09, 2018, 11:11:11 AM »
do not know make , not me who did rebuild
Offline poggy
« Reply #5 on: November 24, 2018, 10:37:25 AM »
latest update - took top end off and found left side base gasket was leaking ( oil was going up studs ) . piston rings are dykes type and well within tolerance . rebuilt and reset timing, now running with both carbs on standard settings and will rev ok but still no power when ridden
Offline AndyDean42
« Reply #6 on: November 24, 2018, 05:22:24 PM »
Can you describe exactly what happens when you ride the bike. It appears what you experiencing is a lack of power under load which could be something a simply a lack of fuel flow. If you have everything set up correctly and an engine will rev freely when not under load there is not much left to try. What do the spark plugs look like after running? Are they sooty and oily or clean, you won’t be able to do a good plug chop if you have no power but the plug always tells a story.
Andy
RD400C, RD350B (new project), GS750E, ST1100 ABS
Offline poggy
« Reply #7 on: November 27, 2018, 09:27:30 AM »
waiting for a dry day to get it back out on the road
