Author Topic: Clutch push rod refurb!  (Read 556 times)
Offline splant
« on: May 19, 2018, 09:34:33 PM »
some of you probably do it already but maybe not , but if you're a skinflint like me or can't be bothered wait for a new one ,if it's got the grooves worn in it where the seal has been just turn it around and reuse it ,,of course you have to make the first 10mm narrower  to fit in the cable arm thingy , I put it in a drill which I put in a vice then angle grind it narrower  ,easy peasy .
oops i think my powerbands snapped .
Re: Clutch push rod refurb!
« Reply #1 on: May 22, 2018, 08:56:40 PM »
cheapskate!  :D or desperate to get out on the bike! lol! should last for a while though,  isn't one end hardened? can you get shaft sleeves this small I wonder?
Has the same problem on a 400 I had once, got a mate to build up with weld then I re ground it, that worked too.
Yamaha 1974 RD125 (AS3) nearly finished!
Kawasaki 1977 z650 B1 being ridden
Yamaha 1972/3 U.S. early RD350 in bits
