Author Topic: Stand springs  (Read 1408 times)
Stand springs
« on: January 17, 2018, 10:58:11 PM »
I have a phobia about springs, dont laugh, I really do, like some people hate spiders etc. Came to the point where I had to fit main stand spring on little rd125 today, felt sick, thought about it for a while and worked out an easy way of fitting without touching it. No fuss, no drama, no faffing with pliers or spring pulling tools,  on in 10 seconds flat.
Used two heavy duty cable ties, worked a treat, just snip tie when in place. Have also used ties as rear spring compressors, cheap and cheerful, must use heavy duty ones though, bit iffy if they break.  :o
Yamaha 1974 RD125 (AS3) nearly finished!
Kawasaki 1977 z650 B1 being ridden
Yamaha 1972/3 U.S. early RD350 in bits
Offline Pielight
Re: Stand springs
« Reply #1 on: January 24, 2018, 01:11:55 AM »
Great tip...wish I knew of it before the wrestling match I had with the main stand spring on my 400c a while back!
Offline Bikerchris
Re: Stand springs
« Reply #2 on: January 25, 2018, 02:55:45 PM »
Good tip. I hate fitting them too!
The other way I have found is to fit the spring at the same time as the stand.  hold the stand in position but only partly push the pivot pin though on one side. Fit the  spring in place, and using the leverage of the stand, pull down on the spring. Helpful to have a second person ready to push the pivot through, or gently tap it with a rubber mallet when the spring has been pulled down enough.
I have done this on a 200 and a 350.
Smokers -
Portugese Orange RD200C - now with a new owner, I'll build another one.
1974 RD350B 351 USA - Nearly finished -
1978 Blue Yamaha RD200E
Garage full of RD200 bits!
Honda 400 Four, Triumph Tiger 100 1965.
BSA C15/B40 (I must be mad!)
Re: Stand springs
« Reply #3 on: November 13, 2018, 11:00:57 PM »
Hi all
Bit late but just use one of these at £1.50 from China81757-0
Does your shoe springs as well.
-Mike
Offline Adeyone
  • 2 Strokes do it twice as often!!!
Re: Stand springs
« Reply #4 on: November 15, 2018, 09:47:58 AM »
+1
Yamaha RD350 1973, 1 of first 700.
Lambretta Li 150 special, now 225cc TS1 with reed valve induction and expansion exhaust!
Honda ST70 Monkey bike, Now finished! FOR SALE!
Offline martin1957
Re: Stand springs
« Reply #5 on: November 15, 2018, 02:51:16 PM »
Another way is to use pennies to extend the spring. Bend the spring and drop a penny in the gap. Bend the other way, drop another penny in. Keep going until the spring is long enough to fit, then just ease the pennies out.
Electronic Test Engineer (Avionics), Age 60, Owned P50, PC50, SS50z, YAS1, YDS7, RD350B till 1978, then KH400 from 2009 onwards. Have a fully restored YAS1 on the road, and an AT3 import to MoT. And now a Suzuki T125 Stinger to get fired up.
Offline ggreen1959
Re: Stand springs
« Reply #6 on: November 15, 2018, 03:49:42 PM »
Clever boy, old timers see!! ;D ;D
Just keep riding.
Offline Aardvark
Re: Stand springs
« Reply #7 on: November 15, 2018, 08:22:40 PM »
I am with Martin, the coin tip is the one to use. 2 pence coins for me.
Re: Stand springs
« Reply #8 on: November 17, 2018, 06:17:42 PM »
omg! thats genius, I am truly astounded by that bit if lateral thinking, fantastic tip!
Offline Bluehaze
Re: Stand springs
« Reply #9 on: December 21, 2018, 04:36:07 AM »
Another method, for use only if the spring has a long loop end. Doesn't work if only a small circular end:
Get a No.3 (big) Phillips screwdriver. A standard No.2 should also work.
Fit one end of the spring.
Put screwdriver through the other end of spring (with long loop).
Place a groove of the Phillips tip on the end of the spring mount lug.
Lever the screwdriver against spring tension, then the spring will slide down it and onto the lug.
It's a quick way to do it.
Offline Bluehaze
Re: Stand springs
« Reply #10 on: January 09, 2019, 08:18:15 PM »
Offline Pielight
Re: Stand springs
« Reply #11 on: January 25, 2019, 07:08:36 PM »
Hi all
Bit late but just use one of these at £1.50 from China (Attachment Link)
-Mike
I used a one of these on my CB1300...hooked over the peg and used to lever the spring onto it. Absolute doddle done in a few seconds.
