Author Topic: Updated carb technical spec  (Read 54358 times)
Re: Updated carb technical spec
« Reply #90 on: November 14, 2013, 04:44:22 PM »
OOhhhhh, me eyes are goin funny :D.
Bit of a mix-up on the third note for 360/361 carbs, "30 and 25 air corrector"?
« Reply #91 on: November 14, 2013, 05:40:27 PM »
What bit is wrong..?
All pre B RD250's are fittted with a 361 carb and a 30 corrector, all 350's are fitted with a 360 carb and a 25 corrector.  :-\
« Reply #92 on: November 14, 2013, 07:32:15 PM »
Well, air corrector jets are usually refered to as say 0.5.  Pilot jets are #25 or #30 for instance.  Is that what you meant?
Offline russiansteel
« Reply #93 on: November 14, 2013, 08:10:12 PM »
and they seem to be 0.5 for both 360 & 361 carbs, meaning the third note is really not applicable.
« Last Edit: November 14, 2013, 08:59:39 PM by russiansteel »
« Reply #94 on: November 14, 2013, 10:06:04 PM »
Yes, got it now............ suffering from number and word blindness there and got mixed up between the pilot jets and air correction and I do know what I'm doing, was getting late last night when I was doing it.............  ::)
Will fix it now.......................
« Reply #95 on: November 14, 2013, 10:42:07 PM »
OK, think that is sorted........... what about the rest now?
I can do this in A3 to go on one sheet but most people do not have an A3 printer.
Latest version:
Offline stephen bailey
« Reply #96 on: November 16, 2013, 07:47:43 AM »
this is a great help my precious !!!! many thanks steve notts
corky
Offline miciver
« Reply #97 on: December 16, 2013, 08:16:30 PM »
Latest version:
Stephen- just checking this is the very latest one?
I am going to strip my 350 carbs this week to see what is inside them before going any further with my resto so would just like to check.
Many thanks for all the hard work on this.  8)
Harley Lowrider S
Harley 1800 Pro Street Breakout
Kawasaki Motors UK Sales manager- south east of England 1979 - 2000.
Bexhill
« Reply #98 on: December 16, 2013, 08:28:03 PM »
I'm still tinkering with it on and off, will do a bit more tidying up and put the latest up later this evening...
Offline miciver
« Reply #99 on: December 16, 2013, 08:38:43 PM »
Great thanks  ;)
Harley Lowrider S
Bexhill
« Reply #100 on: December 16, 2013, 10:56:38 PM »
Latest version.............. On 2x A4's.
There are still gaps in it so need more help to fill it in as I have exhausted my own knowledge and available data that I can find. Someone mentioned the Cycleserve manual, but I have not been able to track this down.
« Reply #101 on: December 16, 2013, 11:25:11 PM »
Haven't got the Clymer manual either....
Yes, 350's 1 3/4 on the unbaffled filter versions, 1 1/4 on the baffled B only.
I had come across the R5C "variant" but had no confirmation if it was so and if it was US, EU or UK....?
As for missing stuff, easier to look at the PDF instead of me putting it all up here, the missing info is left blank.
« Reply #102 on: December 17, 2013, 12:11:32 AM »
Yes, I came across info that the A could come with 3 versions of carb setup.
Most common is the black low-top, un-baffled, 2.5 slide.
Very late A's had Hi-tops that normally would have a baffled filter but as you know, UK data is virtually non-existant, even though we know these setups existed.
So, what I have done is put in the 3 possible setups that an A can run with:
1: low-top un-baffled.
2: low-top baffled.
3: hi-top baffled.
The hi-top did not come standard with an un-baffled filter, always baffled, so anyone with 140 main in a 350A, fittted with a hi-top has had it changed by someone.
None of the A's had the airbox tube correction to my knowledge but that did not effect the jetting across the baffled filter versions.
360/1 is a part code correct, another one slipped through the net, that's why I keep putting this up for scrutiny.
That should be 351/2.
I was contacted by a member that they had a R5C with the same settings as a R5B so I am confused as to what goes in there and there is the possibility that there is a country version here.? Will have to go through all my messages to find out where that came from........  ::)
« Reply #103 on: December 17, 2013, 01:11:11 AM »
Latest version with latest corrections............
Among other stuff still needed, ones with most info missing is DS7, 250E (US) and Daytona.
Offline miciver
« Reply #104 on: December 17, 2013, 07:33:51 AM »
Thanks Stephen, and also everyone else who contributed to this- looks like a minefield.
Harley Lowrider S
Bexhill
