Author Topic: Zeeltronics  (Read 5422 times)
Zeeltronics
« on: August 22, 2011, 10:12:33 AM »
The Zeeltronics PCDI-10 was donated to Project X directly from Zeeltronics
Gazzatt2 fitted it as per the instructions and the unit was pre-set for the RD250E
The bike runs very smooth with it fitted and we have not had to fiddle with it at all.
Today I pluged the Remote computer in to unit under the seat and had a little play.
I have set the rev limiter down to 8000 revs but I dont see the need to play with this system any further.
The bike runs fine on the pre-set power curve one.
There loads of power curvs if you are a fiddler and loads of setting you can play with but as we are not racing this bike i think mits just left as is for reliability.
If I had a RD E version I would definatly fit one of these to mine.
I would like to thank Zeeltronics for this wonderful piece of kit donated to Project X
« Last Edit: November 05, 2012, 08:55:04 PM by Paul Dawkins »
Online mervin
Zeeltronics
« Reply #1 on: August 22, 2011, 11:07:15 AM »
I just got one for my TDR and it controls the powervalves as well but i am having a bit of fun getting it right somehow, it is the same controller as that one and 350 YPVS, with powervalve controller added
no doubt i will get there in the end
Online mervin
Zeeltronics
« Reply #2 on: August 22, 2011, 12:26:36 PM »
TDR Sorted just needed the static timing setting first before the curves work correctly
Re: Zeeltronics
« Reply #3 on: January 25, 2013, 04:55:08 PM »
I have just sent Zeeltronics a message asking for the map for the 350A/B for when Project X conversion is finished.
It should go well with the new barrels and the Zeeltronics set up correctly.
Online mervin
Re: Zeeltronics
« Reply #4 on: January 25, 2013, 05:28:57 PM »
Paul
 with the limiter at 8000 what does it do because i set the limite ron the red line of the TDR and it was flat as a cows collar, put it 200 over and it was a different bike, the limiter seemed to kill it well before the limit was reached
Re: Zeeltronics
« Reply #5 on: January 25, 2013, 06:02:16 PM »
Merv
I have never ridden the bike with the rev limiter set but those that have said it ws as flat as a Honda.
I going to see what Borut says and set it at that with no limiter set.
I just hope it is run in properly before someone thrashes it.
Online mervin
Re: Zeeltronics
« Reply #6 on: January 25, 2013, 07:03:31 PM »
Maybe run it with the limiter on to run in , but really that is not running in, best way is to just let it rev free , but not to fast , and open it up every 10 miles to blow the weeds out is my view, others will differ
