Author Topic: Various parts NEEDED  (Read 3473 times)
« on: February 26, 2011, 11:47:50 AM »
We are now at the finishing stages and we have hit a few problems.
These are the parts needed to finish the project..
Two stroke oil pipe carb connector (Donated by Merv)
Front brake light switch (Donated by nortonrd)
Rear brake light switch with arm.(Donated by Djames20)
Battery strap (donated by Djames20)
Indicator washers front donated by Djames20
Rear sub frame. (Djames20)
Footrest rubbers mounts (To frame) (Donated by nortonrd)
Headlight bowl (donated by Djames20)
Seat strips mounting bolts
Rev counter or speedo ring (donated by Djames20)
Clock fixing kit (Donated by Saddler)
Headlight Bowl plastic spacer x 1
Please can anyone help with these parts???
Offline Griff
  • smokey bacon
« Reply #1 on: April 17, 2011, 12:25:21 PM »
Think I have a plastic spacer for head lamp.
Rubber mounting for rear light, is it the bracket to light one,think I got that part no1A0-847112
I may some other bits about but will have to look
RD350E,RD400E, Triumph 1050 sprint GT.member number 17
wackuk
« Reply #2 on: April 17, 2011, 01:35:15 PM »
Hi i have a brand new rear brake arm and a rear mud guard if they are any good to you.
Dave
Offline rdt400
Re: Various parts NEEDED
« Reply #3 on: April 21, 2013, 07:46:57 PM »
hi there paul, I have got a set of the seat strip bolts with the locking tabs if you want them also have a old head light bowl and also got a rear light rubber mount you are welcome to the lot if you want mate just pm me with a post add , Russ
rdt400
« Reply #4 on: April 21, 2013, 08:01:31 PM »
Thanks for the kind offer Russ but this post is old now and Project X is finished and on the road.
it will be at the rally if you fancy a ride.
Just bring your licence with you.
Thanks again
Paul
