Author Topic: 125/200/fs1e type swingarm bush.  (Read 3463 times)
Offline smokinsimmo
« on: November 24, 2010, 06:35:14 PM »
Rubber cushioned bushes make the rear end feel spongy,  (reminds me of Ford Cortina Mk4+Mk5 void bushes).
Here is a solution I cooked up for my FS1E project to solve the problem.  This will work for the RD125/200 also, but dimensions and bearing sizes will not be the same.  (I will sort the 125/200 bearing problem when the shed gets warmer in the evenings).
Here are the basic parts:-
 Each requires 4 bearings. At about ?6.50 each, (can be done with 2 bearings and central spacer on the cheap), plus bits of scrap tube I had in the shed and some black nylon66.
Pic of stock tube before and after some lathe work:-
Fit some bearings, 4 in this one:-
press in some nylon or oilite end caps and machine flush:-
Fit spacers to suit:-
And here we are:-
The end result:-
Just showing off for now,
And for those Fizzy nuts out there, spot the missing hole in the "new" chainguard fixing bracket.
Paid up Rd club member #30.
 The Original Rally Baby on the electric RD.
T reg angst
« Reply #1 on: November 25, 2010, 04:41:01 AM »
   very good
Offline Panuno
  • Hadleigh, Suffolk
« Reply #2 on: November 25, 2010, 06:24:20 AM »
« Last Edit: July 18, 2014, 10:41:12 AM by Panuno »
Member 117
RD 350B:  K75 'Flying Brick': RD 250B in several Boxes..   Best 350 RD '013
www.admould.co.uk
Offline Ohno
« Reply #3 on: November 25, 2010, 10:49:12 AM »
They look bang on!!
Dont you need some sideways movement in the bushes?
Offline smokinsimmo
« Reply #4 on: November 26, 2010, 05:55:33 PM »
Quote from: Ohno
Hopefully my compound bearing should eliminate this.
Offline Ohno
« Reply #5 on: November 28, 2010, 10:16:41 AM »
If i ever need to replace ill come knocking if thats ok. They look spot on.
Thanks
