Author Topic: First RD250C at 30 Resto an Regular rider  (Read 7484 times)
Offline SteeleRD
Re: First RD250C at 30 Resto an Regular rider
« Reply #30 on: April 22, 2019, 01:27:59 PM »
Just started changing all the fluids so thought I'd check the pump out quite a bit of 2t kicking around not sure if it's been coming from the main shaft few mullered bolts as well.
IMG_20190422_125546_175 by norton.rider, on Flickr
IMG_20190422_125644_172 by norton.rider, on Flickr
Dropped the gearbox oil ready to remove the r/h casing to take the oil pump off.
Pump removed an ready to send off to arrow after finding the leak :)
IMG_20190422_155640896-01 by norton.rider, on Flickr
Gonna check the clutch out at the same time now it's all removed.
« Last Edit: April 22, 2019, 05:48:40 PM by SteeleRD »
30 Year Old Two stroke enthusiast
RD250C 1977 - RD250LC
http://www.aircooledrdclub.com/smf/index.php?topic=58574.0
Offline SteeleRD
« Reply #31 on: April 25, 2019, 03:42:40 PM »
Todays progress
IMG_20190425_152947_218 by norton.rider, on Flickr
Well didn't expect to see this is the Rd250c rear wheel hub previous owner had left the inspection grommet off on the rear wheel hub.
New brake shoes on order for tomorrow an currently going to get some
Me77's fitted :) in a hail storm so glad they are in the back of the car!
Pumps currently away with Arrow for rebuild.
Steady progress interesting to see Yamaha's method for retaining the rear disk carrier compared to how Norton did it.
Offline SteeleRD
« Reply #32 on: May 01, 2019, 03:16:59 PM »
Well the ME77's are fitted! spent today working on the rear hub so that's all sorted ready to fit the brake shoes on tomorrow,
Always been pretty handy at turning new old stock parts up on the elsies, so after a bit of hunting this arrived today!!
One new old stock side panel! Interesting to compare against the current paintwork on the bike :) tank and current panel are totally original and the tank isn't a bad match at all.
While thinking about what to do regarding the tatty repair to the oil tank where the paint's gone on the lead edge of it, I tracked down a New Old Stock Oil tank in the right blue so that's on its way now. For what I got it for be way cheaper than respraying the current oil tank which I'll keep for a spare. Wasn't intending to use nos stuff on this but at the price I got them at well worth it even if I keep them as spares for now :)
IMG_20190501_141309174-01 by norton.rider, on Flickr
Few other remedial bits arrived today as well, new overflow line for the oil tank not got a cats chance of getting the original one back on, some new lines for the crankcase breather, oil tank mounts had all perished so got those to as well as some paint to touch the front of the frame in.
Other one is the brake caliper gonna test fit it over the next few days.
IMG_20190501_140621654-02 by norton.rider, on Flickr
Offline SteeleRD
« Reply #33 on: May 05, 2019, 04:03:35 PM »
Currently working on refitting the rear wheel before I do though decided to start working on the rear wheel spacer another NLA part left is before I started on the rh side of it :) slow progress but think it's gonna come up great.
Gonna have to swap the caliper bolts round as well stupidly tight considering its something that they describe as may need the order changing :) gonna use plenty of masking tape so I don't damage the green bolts.
IMG_20190505_141030924-01 by norton.rider, on Flickr
Offline SteeleRD
« Reply #34 on: May 05, 2019, 07:03:43 PM »
An a lil bit more progress learnt alot doing this one :) good enough to fit now though
Middle stage really really deep pitting.
IMG_20190505_185438_368 by norton.rider, on Flickr
Got the worst of the heavy pitting out she just needs a final polish tomorrow to bring it back to a nice shine.
IMG_20190505_185438_367 by norton.rider, on Flickr
Got the front Caliper fitted bit of a gutter that the supplier supplied the mounting bolts the wrong way round so ended up having to remove them an swap em round green finish is such a pain not to mark.
All in all a decent day an tomorrow I'll get the wheels re fitted to the bike :)
Offline SteeleRD
« Reply #35 on: May 07, 2019, 11:36:00 AM »
Lastest part :) on what's been quite a small parts spend with all the refurbing!
New Old stock oil tank that had been on display in a bike shop. Bike shop is gone now unfortunately.
IMG_20190507_112244_339 by norton.rider, on Flickr
Offline Bofski25
« Reply #36 on: June 02, 2019, 06:40:00 PM »
Not one of my favourite jobs hats off to you keep up the good work
Offline SteeleRD
« Reply #37 on: June 11, 2019, 11:32:24 PM »
Thanks mate :) everything's ready to refit currently once the oil pump is back it'l be time for the first run! Been flying around on my Norton Villiers 1968 Commando the past few weeks been awesome fun!
« Reply #38 on: June 12, 2019, 06:42:04 AM »
For small parts like that spacer, Invest is a small bag of citric acid, rinse steel parts in degreaser and leave overnight in a container with one or two teaspoons full dissolved in warm water. Come the morning you will be surprised how much elbow grease has been saved. Still needs brightening up but it’s a truly joyous moment when you see chemistry doing the work for you!
Offline SteeleRD
« Reply #39 on: June 25, 2019, 01:29:13 AM »
Thanks Peter! Any tips are always greatly appreciated :) should be some progress coming soon oil pump is back an ready to fit itching to get stuck in this week.
Offline SteeleRD
« Reply #40 on: June 26, 2019, 08:13:45 PM »
Finally had a clear day to get stuck in !
She's alive! Well nearly ha  8)
Fitted the oil pump an new seal from the legend that is Arrow, then refitted the side case to the bike, kick start rear brake pedal etc.
Next job was to bleed the lines very painless that's for sure :)
After then fitted some new fuel lines as I wasn't mad on how tight the lines were :) huge progress an tomorrow gonna get her started bleed the front brake an she's ready to rock an roll for friday!
IMG_20190626_191441776-01 by norton.rider, on Flickr
IMG_20190626_191421603-01 by norton.rider, on Flickr
Offline SteeleRD
« Reply #41 on: June 27, 2019, 08:34:18 PM »
She fired up  today sweet as a nut exciting stuff as she's nearly ready for her first ride out :)
IMG_20190627_161915462-02 by norton.rider, on Flickr
Had one issue with the yambits oil union creating a bubble in the line swapping back to gen yam cured the issue :)
IMG_20190627_120329750-01 by norton.rider, on Flickr
Bled the brake an new caliper feels really good.
Test ride tomorrow itching for that.
Got a ton of work done on my Norton-Villiers Commando as well :)
A0005877-2 by norton.rider, on Flickr
A0005882 by norton.rider, on Flickr
A0005893-2 by norton.rider, on Flickr
Offline SteeleRD
« Reply #42 on: June 28, 2019, 06:28:31 PM »
Had the first maiden voyage today!
Was lots of fun she's very raw that's for sure.
Ended up going to a local carb place at a recommendation of a fellow member.
Got a new carb union elbow ended up smoothing the plastic rough casting rib down that's on the raised pointsthat sorted the air bubble out where it must have been sucking air in so for anyone that uses one from Yambits or elsewhere worth trying that.
Just gotta sort the throttle cable out tomorrow as it's revving up slightly when turned left, an the loose indicator bulb in the r/h indicator
Did a plug chop an she's spot on :)
IMG_20190628_173200457_BURST000_COVER-01 by norton.rider, on Flickr
« Last Edit: June 28, 2019, 11:10:57 PM by SteeleRD »
Offline SteeleRD
« Reply #43 on: June 29, 2019, 11:56:26 PM »
https://www.youtube.com/watch?v=KFIU26clom0&feature=youtu.be
First spin on her! Certainly interesting compared to the Elsie and the Commamdo.
Only a 30 second rubbish quality clip but gives ya the idea.
One thing to fix is the r/h indicater has come loose inside the holder an is bouncing round an making a huge rattle
Offline SteeleRD
« Reply #44 on: October 20, 2019, 11:16:49 PM »
What's it like to ride a classic all year round you ask? Exciting exhilarating and freezing haha got caught in an hour downpour on my Yamaha rd250c ! Starting to really catch up on cranking on the miles across the bikes now.
Spent most of the summer riding my daily rider Norton 650SS and sussing out some issues on my Norton Villiers 1968 Commando (previous owner left blast media in the head) so I'm halfway through rebuilding that at the moment.
Been using the aircooled inbetween thrashing about on the 650SS.
Decided today to go to Monyash and boy did we get drenched on the way back haha!! Still thawing out now :) exciting stuff anyways here's some pictures from the cat and fiddle part of the journey :) hope you all enjoy.
73016388_10220097370888965_3641168257303445504_o by norton.rider, on Flickr
73052413_10220097371688985_6985229171198787584_o by norton.rider, on Flickr
72851714_10220097373489030_2206190026960666624_o by norton.rider, on Flickr
74680744_10220097369928941_4557471672747163648_o by norton.rider, on Flickr
75247466_10220097375409078_6943121200159653888_o by norton.rider, on Flickr
73024016_10220097374929066_8425680233553723392_o by norton.rider, on Flickr
72634239_10220097375929091_5255289925749702656_o by norton.rider, on Flickr
« Last Edit: October 20, 2019, 11:23:14 PM by SteeleRD »
