Author Topic: RD400 under construction  (Read 10816 times)
Offline Rd400greenhorn
Re: RD400 under construction
« Reply #30 on: March 11, 2019, 05:55:13 PM »
So, fitted my oem yamaha raptor 660 petcock with a 90 degree outlet. Drilled and threaded and locktite. Hopefully Its sealed tight and works for years to Come.
Also ordered a xs clutch Kit, after advice on this forum, Hopefully it works as attended :)
Tomorrow i Will ask the machine shop thats gonna bore and hone my cylinders, if They Are able to mill out the Reed area, so my v force Will fit.
Fingers crossed They can do it All in house.
Stay tuned folks
« Reply #31 on: March 24, 2019, 08:13:05 PM »
So, my uncle helped me out again, and Got the cylinders prepped to fit the yz85 vforce reeds.
Next i Will be delivering the cylinders to be bored and honed asap.
« Reply #32 on: April 29, 2019, 01:01:34 PM »
So, finally some progress
After receiving the cylinders from bore and hone, i dremeled out the 'bridge' in the in the cylinder ( Reed goes in), cleaned it good, oiled up and Got the top end together. Sprayed it with heat resistent clear coat afterwards to protect the bare alu.
As It sits now
Next i Will try to make a seat pan( No expetience what so ever) in some 1,2mm sheet metal. Hopefully i can make it work
Offline Bofski25
« Reply #33 on: June 02, 2019, 06:29:49 PM »
Looking good keep up the good work
« Reply #34 on: June 19, 2019, 03:30:49 PM »
Sorry for the lack of updates, but life gets in the way.
But, I have stainless news for you, allthough i havent fit Them on the bike yet,
A set of laser Cut and welded, glas bead chain tensioners.
I think They turned out pretty, now They need to fit and Its perfect
« Reply #35 on: July 14, 2019, 08:35:52 PM »
So just a small update, letting the internet know that the build is very much alive
Cut the brackets this weekend under the frame, so the pipes cleared the frame.
Got the hvc cycle sidestand extender on, but Must admit i Hoped and thought it would be a plug and play, it definately not is.
If Iam Lucky i can find some sort of rubber to go on the spring so it wont hit the pipes (as hard) or i Will have to take drastic measures.
Also Got my one off stainless steel chain tensioners on, They turned out good :)
And oh.. Allthough i Cant afford it, (the restoring and custom work etc) i had to buy a New project for the future.
It was a frame with papers, a somewhat complete engine and some other bits and pieces. ( Its not a rebuild, making my own take on it)
Suzuki gt750, ska the kettle aka the water buffalo 😅👌
I just had to do it.
Stay tuned
« Reply #36 on: July 14, 2019, 09:29:26 PM »
Those chain tensioners look good
I will look forward to your GT750 rebuild thread in the near future
« Reply #37 on: July 14, 2019, 09:39:12 PM »
Motty 😁 Thank you
But you have to be very patient because Its gonna be a while 😁
« Reply #38 on: July 31, 2019, 11:16:43 AM »
Small update
Got the newly aquired Throttle tube, grips and cable installed
« Reply #39 on: August 01, 2019, 07:09:04 PM »
A little custom bling for the rd
« Reply #40 on: August 04, 2019, 11:13:39 AM »
Weekend update
1 issue solved, i took the clucht out and the kickstart mechanism, Saw the First shim that goes on the shaft was to big ( having issues with it not popping back up when i kick it)
I found the correct shim, put it All together and it works as intended.
Another one that had been irretating me, was the fact that my clip ons hit the gas tank on Both sides when turned, but i Drilled a 4mm hole in each steering stop on the lower tree, put a 4mm bolt in with a narrow head? And it works perfect, without destroying the tuning radius. Looks fine to me.
Next i Will properly address the tdc
Any tips/ etc on how to do this would be appreciated. I do have a measuring clock? That goes in spark plug hole
Plus i am Also using Electronic ignition, but having never done Any of this before, Please do Come with advice
« Reply #41 on: August 04, 2019, 09:58:40 PM »
Weekend update
Good to see more progress
What electronic ignition are you using?
If it is Newtronics, there is a lot of previous posts regarding setting it up
If it is a different manufacturer, you might want to raise any queries in the 250 and above Tech Help Section
« Reply #42 on: August 05, 2019, 03:06:05 PM »
Thakk you :).
I have a power dynamo ignition
Bought on jim lomas hp.
« Reply #43 on: August 11, 2019, 07:22:20 AM »
Small update...
Brembo, smoked glas, brake fluid resovoir in the front.
Same as in the back
Stay tuned
« Reply #44 on: August 11, 2019, 11:14:49 AM »
Edit
Sorry my reply made less sense than usual as I replied to the wrong thread
However it's good to see progress, however small, to your rebuild
« Last Edit: August 11, 2019, 04:31:24 PM by Motty »
