Author Topic: DT175 not so quick Restoration  (Read 23112 times)
Offline RD17
Re: DT175 not so quick Restoration
« Reply #60 on: September 18, 2017, 10:31:36 AM »
Last few parts now in:
Finally sourced the rear carrier rack and indicators  ;)
Let the build commence!
RD17
Offline chrisg.007
« Reply #61 on: September 18, 2017, 08:12:36 PM »
Looks concourse to me, fantastic. Love it.
Who did the ally polishing?  wow.
Growing old is compulsery, growing up is optional.
RD400D
RD250E  350 conversion
Suzuki X7
RD400E
RD350LC  4LO
Offline RD17
« Reply #62 on: September 18, 2017, 08:39:50 PM »
Hi Chris, I am aiming for a good quality finish across the board, I could not resist restoring it to be honest, it was in desperate need!
The polishing was done by a friend of mine, his work is superb. If you need any polishing doing I can put you in touch. It would take me weeks to achieve the same finish as he does, and his prices are very reasonable. I don't usually like to farm out work unless it's specialist, but his service is second to none.
Cheers,
RD17
Offline RD17
« Reply #63 on: October 24, 2017, 08:54:48 AM »
Progress has sadly slowed on this as I have been super busy with other projects :-\ However the rack is currently being re-chromed and is going to hopefully come back super shiny  :D
I have never had a complete bike in kit form that I have not had time to build up before, then again it should make for a busy weekend  ;)
RD17
Offline Injebreck99
« Reply #64 on: October 24, 2017, 07:34:29 PM »
I am rapidly becoming very happy with my first 2 stroke, a 1973 RD250/350 ,that is nearly fifnshed, I have just been and bought a 1975 DT400 as well, picking it up on Thursday, never even sat on one, fingers crossed.
Offline Levy1982
« Reply #65 on: November 03, 2017, 02:09:39 PM »
Nice to have a quick catch up on this too :)
Loving all the chrome
Sent from my STF-L09 using Tapatalk
Offline RD17
« Reply #66 on: March 26, 2019, 12:13:18 PM »
After a very busy year and a half I have finally got back into this at the weekend!
I have five bikes to build at the moment, but this has been in bits the longest  ;D
Engine back together, just waiting on a few bits. Always nice to assemble with fresh casings, new bearings and seals. Had the crank built and the top end bored a while ago:
Also popped the tyres on, and started building up the rolling chassis at long last:
Coils and points are in need of some TLC:
Gear selector mechanism is very worn, and needs replacing:
Managed to find a fair few NOS parts online, as well as the other bits needed to move the build forward. Looking forward to getting this little beast back together!
Cheers,
RD17
« Reply #67 on: March 26, 2019, 10:32:33 PM »
Nice to see this one continuing!
Offline Alvin
« Reply #68 on: March 27, 2019, 09:33:36 PM »
just read the lot, brilliant work as usual, sunspecks needed as well. 8)
 ;D
RD400. USA "D"
"And the Rodneys are queueing up ,god forbid."
R.I.P Dave Greenfield.....Stranglers  keyboards.
Offline RD17
« Reply #69 on: March 27, 2019, 09:57:11 PM »
Hi Kawa - same here it's really nice to pick it back up  ;)
Alvin - Indeed the polisher did go a bit crazy! They are starting to tone down!
RD17
Offline RD17
« Reply #70 on: March 29, 2019, 09:00:57 PM »
Started 'polishing' up the fins on the barrel and head today. It has had two coats of quality VHT. I am hoping that with the last coat I can wipe the excess off on the fins with thinners and fine wet and dry, I always find that masking leaves a bad edge...
Always a tricky one with these edges especially when they are often not that flat. I can't say I have a good process for doing this - any tips?
Cheers,
RD17
« Reply #71 on: March 29, 2019, 10:12:21 PM »
Yes. I use a Dremel with a coarse grinding tube on it, then use a finer one to finish. Looks superb and takes moments!
Offline RD17
« Reply #72 on: April 02, 2019, 11:55:20 AM »
Hi Kawa,
That sounds like a good plan, I have managed to finish the fins no problem with different grades of sandpaper and scotch bright, it is the masking/post painting polishing that is a bit of a pain! Do you grind through after the final top coat?
Thanks!
Scott
« Reply #73 on: April 02, 2019, 10:20:40 PM »
Yes do it after you've painted it all. I did try sandpaper and it took ages!
Offline RD17
« Reply #74 on: July 22, 2019, 04:22:57 PM »
I’m finally back on the DT175 build.
Headstock in the frame, forks built up and on, as well as the rear shocks! Wheels all ready to go in just waiting for a few seals.
Dropped a bit of black enamel in the side case lettering as well.
The engine is awaiting a CDI ignition that I have worked on to develop, just a few tweaks needed on that before the engine can go together.
A load of rubber parts have been ordered ready for the next assembly weekend.
Further progress coming soon!
Cheers,
RD17
