Author Topic: RD 400 Cafe Racer finished  (Read 10025 times)
Re: RD 400 Cafe Racer finished
« Reply #15 on: June 17, 2013, 07:16:59 PM »
Is the cranked kickstart from an LC ?
Offline [flou00]
« Reply #16 on: June 17, 2013, 08:11:16 PM »
Okay.
The hangers are from a Yamaha YZF 125 (modified).
At the top point I welded a little metal plate (4-5mm thick) on the frame and cut a thred in there. You also can put a tapped bushing in, if you drill a bigger hole in the brace.
And yes the kickstarter is from an 350YPVS.
Offline Preload
« Reply #17 on: June 18, 2013, 08:20:16 AM »
OK Flou00, Nice work I like the stripped down look. 8)
RD350B (Mitsui Mongrel).
Runner up Yamaha Donington Japanese & Modern Classic Bike Show 2013
RD400C (now registered) :-)
FJR1300 Mk1 and best one
Tmax XP500
Nippy Norman
Aprilia Habana
The lastest CBX750F basket case.
RosPa trained & Warwickshire Mag Member
Offline [flou00]
« Reply #18 on: June 19, 2013, 09:24:51 PM »
The fender is a glass fiber reinforced plastic part made by a Yamaha dealer round the corner (Germany).
http://www.ride-in.de/
Offline Butchers
« Reply #19 on: August 14, 2013, 08:17:26 PM »
A very nice racer  8) 8) 8)
opportunity is always ahead if you look and think
Offline 2T
    • 2 stroke Projects
« Reply #20 on: September 03, 2013, 12:16:02 PM »
yes yes - very nice.
i line the minimal look, nice paint/polish finishing
“If everything seems under control, you're not going fast enough.” ? Mario Andretti
Offline Rd400greenhorn
« Reply #21 on: March 29, 2017, 05:15:10 PM »
awsome!
Where did you get that rear section/seat cowl from?
« Reply #22 on: March 29, 2017, 10:28:55 PM »
That I really really like.
« Reply #23 on: March 30, 2017, 10:02:16 PM »
I found it, problem solved👍??😉
« Reply #24 on: November 13, 2017, 02:43:59 PM »
Hi guys
Iam still looking for the seat/fairing - where do you buy it? And is the subframe Stock or modded to fit the seat?
